SHEET METAL
JeremiahJeremiah Member Posts: 1
I Love what Onshape is doing, I will definitely need the sheet metal option.
«1
    jean_didierjean_didier Member Posts: 28 ✭✭
    me too !
    +1 for me with sheet metal. I absolutely need this and would like to think it's on Onshape's list of additions. However at the moment I think there are higher priorities. If sheet metal is 1-2 years away not sure what I am going to do to fill the gap while waiting.
    Jonathon_1Jonathon_1 Member Posts: 2
    +1
    michael_lesliemichael_leslie Member, Mentor Posts: 21 ✭✭
    +1 for me as well.
    caradoncaradon OS Professional, Mentor Posts: 300 PRO
    +1 for sheet metal.
    I already could do a lot with a base flange, edge flanges and unfold.
    Dries
    mikael_jaakkolamikael_jaakkola Member Posts: 8
    +1 for sheetmetal would be one feature that one main competitor fusion 360 are lacking. With basic sheet metal tools and drawings available basic commercial mech design work would be possible.
    teemu_2teemu_2 Member Posts: 2 PRO
    +1 When sheet metal and drawings are published, machine industry and engineering companies start to test Onshape in their projects.
    -Teemu
    +1 for sheetmetal - not directly for me but for the people who desing mechanism that I would like to grab into our furniture desings. And to make hat trick - 3x +1 from Finland in a row ;)
    wynne_fouriewynne_fourie Member Posts: 1
    +1 for me to please
    jim_24jim_24 OS Professional Posts: 2 PRO
    +1 for sheet metal tools... I have to keep SW for the sheet metal currently.
    walterwalter Member Posts: 41 EDU
    3dexter3dexter Member Posts: 89 ✭✭✭
    +1
    marc_de_smidtmarc_de_smidt Member Posts: 2
    I regularly make use of sheet metal, this would be essential for me.
    philippe_carrierphilippe_carrier Member Posts: 1
    +1, Same here.
    Usually, sheet metal uses same algorythm as features that modify solid bodies, like twist and bend. As they are not yet implemented, it might take a while to get these new features.
    navnav Member Posts: 258 ✭✭✭✭
    +1 for sheet metal tools as well
    Nicolas Ariza V.
    adrian_vlzkzadrian_vlzkz Member Posts: 258 PRO
    +1 My backround is sheetmetal! I know of several small shops that would jump on Onshape the minute it has Sheetmetal and Drawings!
    CAD Engineering Manager
    sergio_p_sergio_p_ Member Posts: 37 ✭✭
    +1 for me as well.
    Sergio PLUCHINSKY
    CAD, FEA and Engineering Consultor
    +54 9 11 2250 0564
    adam_mercieradam_mercier OS Professional Posts: 33 ✭✭
    Drawings are a priority but +1 for sheet design too
    alex_sennikovalex_sennikov Member Posts: 1
    +sheet metal
    Bill_StadlerBill_Stadler Member Posts: 1
    +1 Sheet Metal.   A large part of our machines consist of sheet metal and weldments.
    dudipeerdudipeer Member Posts: 1 ✭✭
    +1  Sheet Metal, We are doing electronic packaging most of our designs involve sheet metal
    roger_robisonroger_robison Member Posts: 1
    ++1 on the Sheet Metal and drawings.
    egil_utheimegil_utheim OS Professional Posts: 1
    + 1 for Sheet Metal
    ∞ for drawings :-)
    Stuart_TodStuart_Tod Member Posts: 56 PRO
    +1 for Sheet Metal
    +1 for me
    bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 798 ✭✭✭✭✭
    I would like to design sheet metal parts any time and any place with onshape. I offer my services to help test the functions for sheet metal in a real world environment.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
    scott_baugh579scott_baugh579 Member Posts: 1
    +2 for us here on the need for Sheet Metal
    joe_sullivanjoe_sullivan OS Professional Posts: 4 ✭✭
    +1
    billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,014 PRO
    edited August 2015
    This was a real pain. But it can be done. I'm asking for a trimmed surface from a sketch (basically an extrude with no thickness). With this I can quickly layout a sheet metal part and then thicken the surface into what you see. Turns out I do the same thing in SW even though I have all those fancy sheet metal icons. I think sheet metal as surfaces and then thicken is faster and more robust than the traditional sheet metal features.
    I figure this will get shot down, but just think about it.
    I unfolded this in SW, I would like unfolding added to OS. And while you're in there adding unfold, create a surface flatten tool also. SW should have been able to flatten a surface.
