SHEET METAL
JeremiahJeremiah Member Posts: 1
I Love what Onshape is doing, I will definitely need the sheet metal option.
«1
  • jean_didierjean_didier Member Posts: 28 ✭✭
    me too !
    +1 for me with sheet metal. I absolutely need this and would like to think it's on Onshape's list of additions. However at the moment I think there are higher priorities. If sheet metal is 1-2 years away not sure what I am going to do to fill the gap while waiting.
  • Jonathon_1Jonathon_1 Member Posts: 2
    +1
  • michael_lesliemichael_leslie Member, Mentor Posts: 21 ✭✭
    +1 for me as well.
    +1 for sheet metal.
    I already could do a lot with a base flange, edge flanges and unfold.
    Dries
  • mikael_jaakkolamikael_jaakkola Member Posts: 8
    +1 for sheetmetal would be one feature that one main competitor fusion 360 are lacking. With basic sheet metal tools and drawings available basic commercial mech design work would be possible.
  • LaamuTeunisLaamuTeunis Member Posts: 2 PRO
    +1 When sheet metal and drawings are published, machine industry and engineering companies start to test Onshape in their projects.
    -Teemu
    +1 for sheetmetal - not directly for me but for the people who desing mechanism that I would like to grab into our furniture desings. And to make hat trick - 3x +1 from Finland in a row ;)
  • wynne_fouriewynne_fourie Member Posts: 1
    +1 for me to please
  • jim_24jim_24 OS Professional Posts: 2 PRO
    +1 for sheet metal tools... I have to keep SW for the sheet metal currently.
  • walterwalter Member Posts: 41 EDU
  • 3dexter3dexter Member Posts: 89 ✭✭✭
    +1
  • marc_de_smidtmarc_de_smidt Member Posts: 2
    I regularly make use of sheet metal, this would be essential for me.
  • philippe_carrierphilippe_carrier Member Posts: 1
    +1, Same here.
    Usually, sheet metal uses same algorythm as features that modify solid bodies, like twist and bend. As they are not yet implemented, it might take a while to get these new features.
  • navnav Member Posts: 258 ✭✭✭✭
    +1 for sheet metal tools as well
    Nicolas Ariza V.
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 293 PRO
    +1 My backround is sheetmetal! I know of several small shops that would jump on Onshape the minute it has Sheetmetal and Drawings!
    CAD Engineering Manager
  • sergio_p_sergio_p_ Member Posts: 37 ✭✭
    +1 for me as well.
    Sergio PLUCHINSKY
    CAD, FEA and Engineering Consultor
    +54 9 11 2250 0564
  • adam_mercieradam_mercier OS Professional Posts: 33 ✭✭
    Drawings are a priority but +1 for sheet design too
  • alex_sennikovalex_sennikov Member Posts: 1
    +sheet metal
  • Bill_StadlerBill_Stadler Member Posts: 1
    +1 Sheet Metal.   A large part of our machines consist of sheet metal and weldments.
  • dudipeerdudipeer Member Posts: 1 ✭✭
    +1  Sheet Metal, We are doing electronic packaging most of our designs involve sheet metal
  • roger_robisonroger_robison Member Posts: 1
    ++1 on the Sheet Metal and drawings.
  • egil_utheimegil_utheim OS Professional Posts: 1
    + 1 for Sheet Metal
    ∞ for drawings :-)
  • Stuart_TodStuart_Tod Member Posts: 56 PRO
    +1 for Sheet Metal
    +1 for me
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 871 ✭✭✭✭✭
    I would like to design sheet metal parts any time and any place with onshape. I offer my services to help test the functions for sheet metal in a real world environment.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • scott_baugh579scott_baugh579 Member Posts: 1
    +2 for us here on the need for Sheet Metal
  • joe_sullivanjoe_sullivan OS Professional Posts: 4 ✭✭
    +1
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,099 PRO
    edited August 2015
    This was a real pain. But it can be done. I'm asking for a trimmed surface from a sketch (basically an extrude with no thickness). With this I can quickly layout a sheet metal part and then thicken the surface into what you see. Turns out I do the same thing in SW even though I have all those fancy sheet metal icons. I think sheet metal as surfaces and then thicken is faster and more robust than the traditional sheet metal features.
    I figure this will get shot down, but just think about it.
    I unfolded this in SW, I would like unfolding added to OS. And while you're in there adding unfold, create a surface flatten tool also. SW should have been able to flatten a surface.
