Remove Selection within a Feature
 Cache_River_Mill
                    Member Posts: 225 PRO
Cache_River_Mill
            - Remove Selection within a Feature - When making a selection within a feature, there is not a quick way to start over. If you want to start over, you have to click each selection to remove it. This improvement would allow you to right click the selection box and remove all selections at once.
@PeteYodis I am sure at some stage I had clicked the list with no success, shift-click here would be more intuitive but now I know about the spacebar clear, I like it, a tooltip when clicking/hovering over the list would help let users know about or remember the spacebar clear.
Since the spacebar is large, and easy to target with my left hand - I can hit it to clear the existing selections, even as my right hand is moving my mouse to start the new selection.
Because the selection list box is so small (and often can't be expanded)....it's often easier / faster to clear & reselect than it is to poke around in the list to try to find failing / missing selections.
I know there are IRs on that side of things...
I've been through the training classes and believe it's in there.
Can't imagine living without it.
Broke the spacebar on my laptop because spacebar clears selection and had a new keyboard installed under warranty. I use the spacebar a lot. Butterfly keys are on their way out for this reason.
So few people read this forum, I'm really shocked that more don't.
I use the spacebar to clear my "active selections" a lot, but hardly think about it when I have a list of parts. In my mental model "list of things to apply this feature to" is not the same as "active selections". Also, when the list is visible, things highlighted on the model are "things that I've added to the list", which, in my head, is also not "active selections".
Not sure if those thoughts help, but I think that's why I don't think about using the spacebar in this situation.
