Improvements to Onshape - October 1st, 2019
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221
edited October 2019 in New in Onshape
It's the first of October, exactly 20 days have passed since our last update and we are ready for another! This update focuses on usability and performance improvements in many different areas of Onshape. Let's dig in.
CAD IMPROVEMENTS
HOLE TABLE IMPROVEMENTS
We announced the addition of Hole Tables in our last release. In this update, we've made multiple improvements that make them easier to use.
https://onshape.wistia.com/medias/4jsjmdxnx5
GEOMETRIC TOLERANCE SYMBOL IMPROVEMENTS
You can now attach Geometric Tolerance Symbols to dimension extension lines in Onshape Drawings.
https://onshape.wistia.com/medias/1c2svp14bf
SHEET METAL IMPROVEMENTS
Improvements have been made to Sheet Metal in Onshape to better handle multi-edge bends in a single feature. This makes Sheet Metal more robust in situations where you have cuts across the bend.
https://onshape.wistia.com/medias/06k0cmrz3v
SEARCH RESULT IMPROVEMENTS
Part number, revision, and state now appear below the name when searching in Onshape. This makes it easy to see important information about the thing you are searching for without needing to open it.  You'll also notice a new icon   has been added to indicate "Latest Revision."
https://onshape.wistia.com/medias/10rkhf0123
DOCUMENTS PAGE IMPROVEMENTS
You will now see the most recently edited branch when viewing the Documents list from the Documents page.
"SWITCH TO" CONTEXT MENU IMPROVEMENTS
When right-clicking a part in an assembly and using the "Switch to" command, you will now see icons to better delineate between the Part Studio and Assembly.
glTF EXPORT OPTION
You can now export parts and assemblies to the glTF file format.
LARGE ASSEMBLY PERFORMANCE IMPROVEMENTS
Changes have been made to improve large assembly performance in several areas. This includes changes that allow Onshape to open bigger assemblies, improve selection/highlighting performance, and decrease load time.
ENTERPRISE IMPROVEMENTS
DASHBOARD PERFORMANCE IMPROVEMENTS
Performance improvements have been made to reduce load time of many of the Analytics Dashboards in Onshape Enterprise.
LEARNING CENTER IMPROVEMENTS
"INTRO TO CAD" COURSE
You will find a new "Intro to CAD" pathway in the Learning Center. This pathway is composed of four new courses, geared to new CAD users and focuses on understanding how to model in a 3D parametric feature-based CAD system, using Onshape.
Remember: The updates listed here are now live for all users when creating new Documents and over the next few days these features will also be available in Documents created before the date of this update.
«1
    ah what a nice surprise to see today!  Really elegant improvements.  Makes me want to do more with sheet metal and holes.
    www.accuratepattern.com
    Nice QOL improvements :)
    Thanks for the switch to icons! Now I don't have to label my part studios with a "parts" prefix/suffix :)
    I wasn't even aware you could select the bend radius like that when importing.. I always deleted the fillet's face and did it from square edges lol..
    Thanks for the lesson, and the bug fix I wasn't even aware of :smiley:
     :) Ok, great improvements
    Un saludo,
    Loving the icons, thanks Devs :)
    Happy Onshaperist over here :+1:
    Cheers,
  • gerhard_swanepoelgerhard_swanepoel Member Posts: 29 PRO
    Great sheet metal improvement.
  • FERNANDA_RAMIREZFERNANDA_RAMIREZ Member Posts: 2
    Nice improvements!
  • romeograhamromeograham Member, csevp Posts: 713 PRO
    Nice improvements to Search Results...
    ...and there's even a little icon that lets you know if it's the latest Release AND the Revision:
    Nice work folks.
    Awesome, thanks for the update. The search improvement are very welcome.
    I have not tried it yet but hopefully the sheet metal multiple bend edge shows up in the drawings as a single bend rather than multiples.
    @cody_armstrong
    What is this in the changelog?
    FeatureScript: Ability to name faces and have it export with Parasolid model
    What has it changed in FeatureScript?
    Oooh, is this the first step towards MBD?
    @owen_sparks  - it's for third-party apps to maintain associativity (for example, name faces for simulation boundary conditions).
    @MBartlett21 Nothing has changed in FeatureScript (I haven't looked at it myself, but I assume face naming is done with attributes), it is the Parasolid export that has been improved. If my assumptions are incorrect I will let you know!
    @cody_armstrong
    You can use something like
    setProperty(context, {
                "entities": someFaceQuery,
                "propertyType": PropertyType.NAME,
                "value": someString,
                "allowFaces": true
    which will add a name to a face and this name will be preserved with Parasolid export.
    Neil is actually a bit incorrect in that it was the setting of properties that was updated and the Parasolid export that didn't change.  We try to preserve properties on export, even ones that aren't possible to create in Onshape and should be true if you upload some foreign data and export it to Parasolid.
    Neil is correct that it is work done to allow for third-party apps to leverage named faces for associativity.
    Jake Ramsley
    So... we could
    1. create a FS to add information on some faces
    2. export to Parasolid
    3. Import in SolidWorks
    4. Run a macro in SolidWorks and read that information
    Am I right?
    Un saludo,
  • Cache_River_MillCache_River_Mill Member Posts: 225 PRO
    Take my money!! These are great improvements.
    Thank you Onshape.
    I love the new course "Intro to CAD".
    I´m glad to see that there are many similar things in our own Onshape course in Spanish. But, of course, you have a better team of illustrators ;-)
    Un saludo,
  • paolo_ciancipaolo_cianci Member Posts: 22 ✭✭
    edited October 2019
    With the latest update on ios, the sketck tab and measurement information are hidden at the bottom
    "Solved thanks"
  • jonathan_sessajonathan_sessa Member Posts: 11 EDU
    cant wait for mirroring in assemblies
    Un saludo,
    edited October 2019
    gltf
    hohoho Merry Christmas!
    gltf is a standard for transferring the display list from onshape to webgl (the browser's graphics engine). There really is no need to have this translation unless you want to spin your OS models on your website. It's a developers thing.
    This weekend, I'll be updating my website.
    edited October 2019
    Cheers,
    On second thought the icons are a great improvement but they could be, um, greaterer.
    As it stands:-
    If we want the part studio we click the grey rectangular-ish icon.
    If we desire the assembly we click the grey rectangular-ish icon...
    That rather defeats the purpose of icons doesn't it?
    If we think of every day real world cues, say traffic lights,  they're all round lights but we determine an action based on colo(u)r not on shape.
    I get the feeling that if onshape designed road signs they'd all be grey :p;):s
    Rant mode off, and thanks for listening.
    Cheers, Owen S.
    Cheers, Owen S.
    Maybe there is Finnish UI designer? Look at our traffic signs and you see we love icons w/o any text that you just need to memorize and most of them have same shape and color.. And during winter they all turn into white/grey with fuzzy icon =)
    Thanks for the update Onshape crew. It seems like I really have to dig into my FS and convert those cut-out cylinders into proper holes..
    @owen_sparks
    It is very hard to pick colors that are universally accessible to people with different forms of colorblindness.  Differentiating things based on shape when possible adheres much better to modern accessibility guidelines.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 556
    Our state indications on search results, while using colors - do show the full text of the state they are indicating, and so they work for a range of people.  We have noticed other modern platforms indicating state or status in a similar fashion.
    I am finding the part studio/assembly icons in context menus much easier to find. I will take monochrome over nothing any day.
    becides, the clean/grey look is the main theme on Onshape since the beginning. Until they add custom themes/icon themes, there is no chance they will sprinkle color into the UI randomly :/
