Mirror an assembly
bill_danielsbill_daniels Member Posts: 282 ✭✭✭
Unexpectedly, I have a need to mirror a large assembly.  Anyone have a shortcut?  I really don't want to rebuild the entire assembly.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,035 PRO
    No assembly mirror yet. :(
  • Lucas_KuhnsLucas_Kuhns Member, csevp Posts: 105 PRO
    Have fun rebuilding, I have some waiting for rebuilding too. Maybe if we wait for the next release there might be a solution.
    Really, if the assembly is truly a mirror. I suppose a shortcut would be, create an in-context part studio, transform/copy in place everything.
    Then insert the part studio into a new assembly. Then Group everything static. Then add the minimal amount of moving mates (revolute/slider, etc)
    should still function the same as an assembly mirror.
    #untested
    #untested
    yes but to maintain part instance for non-changing geometry you have switch parts out for existing parts, which is the time-consuming process and also becomes a pain after changes are made as repositioning is not linked.
    Ah yea, durp... it won't work for part instances.. blah
