Exercise Clamp
assane_fall
Member Posts: 6 EDU
I was doing Exercise clamp .but I can not get same results. its like there is something wrong with the data
Help please,Thanks
That lesson has many sketch entities and constraints. It is more likely some minor detail like a constraint got missed (or added unexpectedly) while you were sketching.
Can you please post a link to your document and describe what exactly is not working for you?
Instructions of how to link your document are posted here: https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
Please set it to public so we can view it
- rmb > suppress all your mates
- unfix rod
- select front face of rod
- drag triad origin to center of face
- rmb > move to origin
- fix rod
- unsuppress mates
and redo step 10 and select the correct geometry
