Sending a message to the owner
rune_thorsen229
Member Posts: 182 EDU
Hi when finding something useful among the public documents I'd like to send a message to the owner like asking for permission to use the design or propose a collaboration.
How can I do that?
How can I do that?
NeilCooke Moderator, Onshape Employees Posts: 5,767Unfortunately, there is no way to do that - it would definitely be useful for collaboration. Content in Public documents is public domain so you don't need the owner's permission to use it. However, we have no control over what content is being uploaded and whether it is infringing somebody else's copyright.Senior Director, Technical Services, EMEA1
NeilCooke Moderator, Onshape Employees Posts: 5,767^ what Owen said. By default, the first tab is the one that is displayed when first opened, so if you put a PDF there, everyone will see it (Feature Studios do not display on mobile). You can also add information to the Document properties (in hamburger menu top left) that will display in the Document info panel on the Documents page, but that is not as obvious,Senior Director, Technical Services, EMEA6
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646FYI for everyone posting links in this thread, the `/e/aa112233bb4455` portion identifies the tab, so once you copy and paste that, everone who clicks it is always going to go to the tab you were currently on when you copied the URL. If you just go to say:
https://cad.onshape.com/documents/ea73831031c68a9ca068365e
The system will have to infer a tab for you.
So if you ever click a link with /e/ in it, the tab has already been chosen for you.Jake Rosenfeld - Modeling Team2
Negative, the tab it was created from doen't seem to matter as this was created firs with a Sketch then the PDF was added: https://cad.onshape.com/documents/0a30ad4b2556d4120059fb8f/w/be7effe649adf04ef4cbb4f5/e/a0bfa12ea865a6eba3c59978
But I realized that you don't give view access to public documents. If thats the case, it is A GREAT PITY (I guess google documents beat you on that ;-)
Your link took me to the pdf page sucessfully. If you're seeing different it's possibly because you're the owner. What happens if you open in in incognito mode?
It opens the tab: Stick_2.0
If I search FeatureScripBelt and open it, it opens first tab
https://cad.onshape.com/documents/57886eace4b0e425c1ef548a/w/54f180f432defb41a8fddb17/e/c65e445e89ee373617edc394
Opening tab belt.svg and closing.
Searching again it goes directly to belt.svg
Conclusion: you may be right.
By the way an exellent example of how to go around my initial question. Thank you so much everyone.
Rune
