Feature request: perspective view in drawings
johan_van_ravenhorstjohan_van_ravenhorst Member Posts: 20 ✭✭✭
In a drawing, it is sometimes helpful to have a more "human" view of a complex product in addition to only isometrical views.
So hereby the request for a feature to insert perspective views to drawings.
I am not the first, see also these related posts:
  • henrikhenrik Member Posts: 2 ✭✭
    Would be nice to have this natively (and easy to update).
    But googling for a solution, I got my job done using the workaround with a screenshot of a "hidden edges removed" view (described in the first link Johan posted above).
  • jacques_spillmannjacques_spillmann OS Professional Posts: 72 PRO
    @Onshape, Any news on this? I desperately need a solution to export perspective views in DXF format to later use in Illustrator...
  • PeterMPeterM Member Posts: 24 PRO
    You can make a named view in your model and insert this in the drawing. I believe this should solve the issue. https://www.onshape.com/cad-blog/tech-tip-using-named-views-in-onshape
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    edited June 2020
    @PeterM They are asking for a perspective view in a drawing.
    Although you can store the projection type in a named view, drawings will not let you select those named views that are perspective
    You are right, @john_mcclary. You can insert named view of parts in perspective view though, but not from assemblies. That is my experience. Vote this request up!
  • KuklaKukla Member Posts: 1
    Have there been any updates on this? We use perspective views all the time for our customer approval drawings and need to be able to add them to the drawings. I have to import a screenshot .jpg into the drawing as a work-around.
    With Onshape new ability to export a drawing in SVG format (sweet!), if only we had the option to use named views that have "perspective on" in drawings would be awesome! This would be just for display and doesn't need to be "dimensionable"...
  • jr_vrvrknjr_vrvrkn Member Posts: 125 PRO
    any news on this? marketing doesn't like ortho views ;-)
    If it's for marketing, try rendering.
    Then put the image on the drawing
    any news on this?
  • S_LaurentS_Laurent Member Posts: 9 PRO
    Up
  • darth_pixeldarth_pixel Member Posts: 12
    as for me there is no other option to work in 3D but the perspective view
    this is how my little brain works
    i event use it while drawing sketches (in any app that allows it)
    so definitely upvote
  • martin_kopplowmartin_kopplow Member Posts: 1,078 PRO
    edited February 3
    Doesn't seem to be possible yet. I seldom need perspective views in drawings, but for those rare cases I do (Architects!), I sometimes fake a perspective overview by adjusting my model view as required, set perspective, switch render mode to unshaded, then just make a screen shot and place that on the drawing sheet instead of the usual isometric view. It's not the real thing but satisfies most requests.
    It would still be good, if we could get a perspective view out of Onshape, in line art, as a DXF, PDF or SVG file. That'd help communicating with illustrators and artists of all kind.
