Zip ties?
imants_smidchensimants_smidchens Member Posts: 64 EDU
I'm working on a CAD project for our robotics team, and we've taken to using zip ties for not only wire management, but also for attaching lightweight components in places where a custom 3D printed mount (or something similar) is less practical. However, in previous years we haven't taken the time to add screws/bolts/chain, let alone zip ties.
I'm trying to implement better CAD practices across our team - leaving no screw un-CAD-ed, we found an excellent chain/belt featurescript, but I'm at a loss for how to do zipties.
Is there a featurescript out there I'm unaware of, or is there a better way than creating unique, custom, in-context parts?
  • imants_smidchensimants_smidchens Member Posts: 64 EDU
    one thing I'm considering is using the wire featurescript to create a replication which approximates the dimensions, would this be a valid way?
    if you want to show your zip tie then I would draw a box to represent the head.
    Draw circle or a box with a spline to create a path for your strap.
    Configure your shape as needed.
    Then draw your strap rectange and sweep along your path
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    Alternatively, if you are creating assembly drawings you can just call out the zip tie locations via flag note.
    Right, that is all I would do in a professional environment. The model itself is just fancy fluff for the marketing department.
  • fnxffnxf Member, User Group Leader Posts: 145 PRO
    Have a look at this: https://cad.onshape.com/documents/bd1ab9b3ce22193d6cab1fcb/v/5cddd092347747326f80ba5a/e/1585fa2a8d699d6318e9a552
    Maybe a bit complicated- but if you'd just take the "Part Studio Zip tie" and put it in a stand-alone document, you'd be ready to insert this in any assembly. The diameter of the zip tie can be adjusted during assembly. Feel free to copy and improve :smile:
  • EvanReeseEvanReese Member, Mentor Posts: 2,403 ✭✭✭✭✭
    I think folks are right that they aren't strictly necessary. The only reasons I can think that you'd really care to have them in there are:
    1. identifying potential collisions
    2. renderings and other images
    3. personal satisfaction
    but if I were doing this, I'd do something like @fnxf suggests and make a single configured zip-tie part to bring into the assembly. I might suggest adding several configs. One table for the sizes you know you'll have (could be small, medium, large) and also the diameter it's going around.
    I would add
       4. assembly instructions
       5. correct BOMs
    Good suggestion, @Evan_Reese. In my experience, small and large are enough, e.g. 120 mm and 250mm length. And I'm really a fan of the new Q-ties from HellermanTyton: https://www.hellermanntyton.com/products/cable-ties-inside-serrated/q120i/109-00053
    fnxf said:
    I would add
       5. correct BOMs
    excellent additions!
