Topographinator (Update)
MichaelPascoeMichaelPascoe Member Posts: 2,688 PRO
edited September 2020 in FeatureScript
     Topographinator
Link
https://cad.onshape.com/documents/af87f92a8aacda9b29d58899/w/895817513a38f6bc735f701b/e/4782d8b17fc1f4ca112070c4
Created by:
Michael Pascoe, Cache River Mill.
Description:
This custom feature extrudes your
sketch into multiple layers.
Prerequisites:
A single sketch containing 3 or more fully enclosed shapes.
Notes:
  1. The order that you draw the faces will
be the order that they are extruded.
  1. Choose the layer thickness.
  2. Select a center face.
  3. Select the outer face as a boundary.
Application:
This feature is most useful when you need to stack multiple layers of plywood to create the base for a glass top river table.
