Making the front of a Diamond Play Button
charlie_kingsland
Member Posts: 10 EDU
I have a basic shape for a diamond play button, i was just wondering how I would create the raised-ness of the top of the play button... Any ideas? I have the basic lines drawn on a sketch plane, I just do not know how to extrude lines...
EvanReese
Member, Mentor Posts: 2,884 PRO
Ah I understand now (I think). This is actually something I've wanted from time to time and would love for it to become part of the loft feature. Good question @charlie_kingsland I don't know a simple way. All I can think is a lot of separate surface lofts, like this. You can get in a groove and use some hotkeys to knock it out fairly quick, but it will be a somewhat fragile model that will break if you try to tweak it much. At least it wouldn't be up to my ideals of stability.
https://cad.onshape.com/documents/d240295fe07839f9d33d55ff/w/0b89fceb05c86dfd59595482/e/2b7ac33e3faa033aa83b86ba
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/db2257daeec52e4619ef2cc4
You can get around this for simpler surfaces by just compiling a bunch of 2D surface lofts and then creating a solid from the closed surfaces (kind of like a tent).
