What are your top 10 most commonly used materials?
in General
This discussion has been closed.
abs
nylon 6/10
4130
1020
316
silicon rubber
mic6
pla
I don't have a 10th.
1. Aluminum alloys 2024T3 / 6061T6 / 7075
2. Steel & Steel Alloys
3. Brass
4. Carbon Fiber
5. Titanium
6. Copper and Copper Alloys
7. Nickel and Nickel Alloys
8. ABS
9. Fiberglass
10. Magnesium and Magnesium Alloys
2. PC-ABS
3. POM
4. Cold Rolled Steel
5. Hot Rolled Steel
6. Stainless Steel
4340
O1 or perhaps D2 (tool steel)
8620 (case hardening steel)
316
2025 (duplex SS)
17/4PH (precipitation hardening SS)
Aluminium Bronze
Acetal
Alu alloys 5000 and 6000 series
It would be good if the pre-allocated materials were generic insofar as properties, especially density, were concerned.
To elaborate one example: I would rather see "mild steel" than a tighter designation which might apply only to barstock, or to structural steel, or to sheetmetal. But it would be nice to be able to edit the default material to a more specific spec, using the supplied properties as a jumping-off point, and save this alongside (without modification to) the default options.
(EDIT: don't know why I didn't see the tagline....got my answer.)
Original Design was all analog instruments, we modified the avionics to full glass cockpit displays.
or just "Plastic" and "Resin"!
Oh, and "Metal"
Aluminum A380 Die Cast
303 Stainless Bar
17-4 Stainless Bar... PH conditions H1150, A, and H900
416 HT Stainless Bar
Steel Bar 1144 CD Stress Relieved
Structural Steel A36
Steel Bar ETD150
Ductile Iron 80-55-06
Ductile Iron 100-70-03
Shucks, is that 10 already... alright attached is the full list... Enjoy!
below material used frequently in our daily life,
Also see the material used list attachment.
With warm regards,
Virendrasingh Yadav
Aluminum
Steel
Bronze
Copper
I would probably not trust your densities for any composites or plastics unless they had references to a specific product line and manufacturer.
My internal materials lists have info on the source of the info as well as a 'checked by' field to differentiate quick and dirty entries from researched and vetted entries. Having similar fields (or a notes field) for custom materials would be important to me.
360 Brass
12L14 CRS
316L SS
Cast Iron
Delrin/Acetal
HDPE/UHMW
PTFE
CPVC
1018 CRS
10x Custom material with custom name and properties would a good start.
My top 10 materials:
- MFC (melamine faced chipboard, density varies with thickness)
- MDF (usually painted)
- Abs, Pvc, other plastics
- Aluminium
- Steel
- Zamac
- Veneer
- Massive woods
Definitely need possibility to set part/assembly mass properties according to real world piece when modeling something that already exists.
Alloy Steel 4140, Bis, hardox
Cast Steel
Cast Iron
Aluminium
Rubber
Poly Urethane
Abs, Pvc, Nylon other plastics
Glass
Tungsen Carbide
Ability to spec a weight with an override, real world weight.
Ability to link to a standard company material listing. eg Spec the desired RHS steel tube from the company's list inside Onshape and properties auto propergate to the part. This is what we do in SW https://forum.onshape.com/discussion/191/properties-material-properties-and-drawings
Raino
Thanks!
Jeff
6061-T6
6060-T5
5052 H32
5005 H34
Steel;
316 SS
304 SS
AS/NZS 1594 HA250
AS/NZS 1594 HA350
Plastics
30% Glass Filled Nylon
ABS
PP
UHMWPE
HDPE
LDPE
Polycarbonate
Half Hard Brass
Aluminium
Wood of various kinds
ABS
PLA
ABS-PC
Polycarbonate
PC-Glass filled%
6061 Aluminum
Nylon
Nylon-Glass Filled%
Stainless Steel
Rubber
HDPE
I was initially a bit surprised that there were so many types of wood and so few types of carbon steel (26 vs 2), no medium or high tensile or tool steels at all (but three grades of Nickel, plus cupronickel and nickel silver !)
but there's something there to approximate most of the materials I use, which is as much as anyone can hope, and I do recognise that all carbon steels are effectively the same density, which can hardly be said for wood.
Acetal/Delrin
Brass
303 stainless
1010 steel
4130 steel
