I love the variable studios
There is also a small improvement that you can add to the changelog...
Draft feature remember previous angles
What's also frustrating is that in order to see the revision of the parts, I need to either look at the BOM with a revision column, or the revision history or properties for the part. It would be nice if this was an optional column in the part list or at least something which would show up in the tooltip for the part.
[Oh and BTW, what does the <1> or <2> etc mean after an instance name in the list of parts? I can't find it in the help]
example:
"Your sensor is crashing with the part"
"where?"
"click on the sensor in the tree, it's instance <6>"
To circle this back to the main topic, there are two items ("Fork, 6mm Rake" and "Front Fender, 6mm Rake") which are set at a revision here, but show with an update icon instead of the triangle, despite the recent updated functionality. In a way this makes sense, but it might be nice to have an indication that they are at the most recent revision, but not the most recent version. If I go to a version of the assembly, then the triangles show up.
There are never two instances of the same object with the same <x>
"Front_Fork_cover_L_MTS_A1"
"Front_Fork_cover_R_MTS_A1"
"Side_Refl_Sticker_Left_OTS"
"Side_Refl_Sticker_Right OTS"
there are no two names between the " " marks that are identical.
They either say, LEFT or Right, or L or R, or Front fender being completely different altogether.
________________________________________________________________________________
here you see I create a simple part, then make a pattern of the part.
See how it gets a new name and a new place on the part list?
That means it has its own unique internal ID. Even though the geometry is identical, they are like identical twins, but they are still unique.
Now I bring them into an assembly,
each part gets a <1> since it is the first instance known to that assembly.
then I make a copy of part 2
it counts up +1 for each copy.
Then I make a copy of part 1, it also counts up (from 1) for each of its copies.
Does that make more sense?
Thanks for doing that. Everything you demoed follows my experience and expectations. What I still don't understand is why I have 5 unique parts which all have instance numbers of <2>, when there's no other copy of the same part. Perhaps I assembled two copies at one point and deleted the <1> instance? In any case this probably belongs in a different thread.
so you create 10 copies, then delete all but instance <6>
you will be left with "Part 1 <6>"
And also Named Positions- though to me Named Positions and Named Views is the same feature- more or less..
Well done.
https://cad.onshape.com/documents/a5a51681e417ade431aedff4/w/b3fad3af49a379898da960e8/e/bec8f8e2adc23490dccd02bf
ps. Chart is from Metal Supermarket.
Interesting, That is the first thing I did with it too.
pipe threads but still not external cosmetic threads.
Improvements to Onshape - April 5th, 2022 — Onshape
We have more to do in this area, but this is a start.
One immediate suggestion would be to bring the configurations panel to the Variable Studios. That should allow the user to manipulate and control multiple variables by changing a configuration input, which is very handy in the current Part Studios.
