Improvements to Onshape - August 6, 2015
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
Today I am excited to tell you about a number of new features that have been added to Onshape. Many of these were among the top requests submitted and we look forward to having you give them a try.
Highlights include:
Remember: The updates listed here are now live for all users when creating new documents and over the next few days these features will also be available in documents created before the date of this update.
UPDATE: For those of you that had mentioned the drill and countersink angles were off in the new Hole feature, we have updated this so all new holes should be correct.
Highlights include:
- NEW Hole feature - Add various hole types into parts (Part Studios) with stack and depth intelligence.
https://youtu.be/408ixoD64QM - NEW Derived feature - Add existing parts, sketches, planes, helices, and mate connectors into another Part Studio. This is linked to the original and any changes will update everywhere the derived feature exists.
https://youtu.be/E5y3P8vs5fY - NEW Import DXF/DWG into sketches - Import DWG/DXF in as a sketch in Part Studios. This is a powerful way to re-use legacy data for profiles in Onshape.
https://youtu.be/XWLQ5EMPRZo - NEW Mate limits - New option in all mates except ball and fasten to limit the range of motion.
https://youtu.be/qO8FYWtO6SQ - NEW Materials - New option for part properties -> Assign materials. Materials assign density and is used by the measure/mass property tool for parts and assemblies. Unit settings also were updated for options for mass.
https://youtu.be/zcpD241Hth8
- Document page filters - If you have a filter set (i.e. Shared with me) and enter a document, clicking on the Onshape logo or the hamburger menu (three bar upper left -> Close document) will return you to the filter you were in and the previous scroll position.
- View constraints (when errors exist) - We made some adjustments to easily see constraints when something is wrong. This is the first step to being able to manage your constraints and the first priority was to make sure when something is wrong, you can see it.)
- Document size - There is now a column to show the document size.
- Update UI in Manage account screens - A little cleanup, additions and responsive layout or the Manage account screens.
- STL out from Assemblies
I don't normally comment until I've had a chance to try stuff, but I just couldn't contain myself that long.
Forza, Onshape!
To keep you going; add parametric (named) dimensions and I will begin moving product data in!
I think we need 'clear history' button for reducing filesize if history isn't needed anymore (archive).
I am also with you on the naming and link dimension's. Is this logged for voting on the improvement request?
Materials are great, but I am wondering how you chose what materials to put on the list. It does not have PLA plastic or medium-density fiberboard, but it does have plutonium. What are people designing with Onshape?
As others mentioned above, parametric dimensions and drawings would be the last two pieces of the puzzle for me. Getting very close to turning the CAD world upside down.
I think we don't need votes for parametric dimension anymore if I have understood correctly it should be on the tube already.. Can you confirm the need for votes on this @lougallo ?
https://onshape.zendesk.com/hc/en-us/community/posts/204547138-Constraints-1-Viewing-and-deletion
thanks
The issue with that is you have the maximum angle less than the minimum angle. 0° ≤ θ ≤ -45° is an unsolvable equation.
edit:
My mistake. I forgot there is a current limitation with handling negative angles in limiting revolutions.
and reset works as I think it should: it repositions to the least negative value.
(Reset is GREAT in combination with limit mates. BTW, giving easy toggling between three defined positions. Fabelhaft!)
But negative values seem to instantly raise a red flag in angular mate fields wherever I've tried them, regardless of which field, and what the other field contains, as @nav reports.
Naturally there are workarounds, involving reorienting the secondary axis so both values can be non-negative, but it would sometimes be nice to have the flexibility to work both sides of zero ...
Certainly that allows setting any one position without reorienting the secondary axis, but I don't see that it permits setting two arbitrary limits, especially when there are two possible directions between any two angular limits which are not at 180 degrees (the 'short way' vs the 'long way')
Linear limit mates currently allow the setting of three positions (as I mentioned above, this is fantastic)
So it seems to me very limiting if angular mates can only work to one side of the nominal position, and it means only one or at most two positions can be meaningfully defined.
I don't see any merit in going past + or - 360 degrees, so I'm not sure that's a relevant issue?
Without this ability, much of the detail being discussed re materials, I would have though irrelevant.
Best regards
Martin
