Appearance Deletion Example Needed
anddy_archeranddy_archer Member Posts: 8 ✭✭
OK, this is really frustrating.  I seem to find "answers" to my question but I can't for the life of me get a "delete" option in the menus from the face appearances in the right panel.
These three threads all stop at the assumption that I can figure out how to get that menu+delete to show up.  I feel like a doofus, but I gotta ask for someone to share one of those nifty short animated gifs of what I'm doing wrong--or something.
https://forum.onshape.com/discussion/15147/rendering-how-to-remove-a-feature-appearance
https://forum.onshape.com/discussion/18325/is-there-a-way-to-remove-all-face-colors-from-a-part
https://forum.onshape.com/discussion/18174/how-do-you-undo-an-appearance-change-to-revert-to-the-default
Very simple example:
https://cad.onshape.com/documents/07597dd2ba291fef32d21a1b/w/ba75ba581afe68b1a4a73c4c/e/e050e55a2185798781a0b2b8
The main reason I want to delete these is so when I export there aren't any materials included.
    You can’t delete a part appearance, only a face appearance. It’s just a colour so just set it to grey if you want to export it grey (no material props are exported).
  • anddy_archeranddy_archer Member Posts: 8 ✭✭
    OK, Bummer.  I could have sworn that the parts didn't show up in that list until I added some colors to test things out.  I'll just live with it.
