Sweep Separate (New Custom Feature)
MichaelPascoe
Member Posts: 2,766 PRO
Sweep Separate
Link:
Created by:
Michael Pascoe, Cache River Mill.
Description:
This custom feature sweeps the selected faces as separate parts.
Prerequisites:
Faces to sweep.
A path to sweep along.
3
I gave the Onshape team some featurescript feedback from a non coders point of view. As usual they were very attentive and might even add examples for everything in the featurescript documentation!
Usually what happens for me is that I can find what I need in the documentation but I have no idea how to use it. Simple "one line" examples of everything in the documentation would be so useful.
- Creating input boxes.
- Creating variables.
- How to use queries. Lots of examples.
- Adding an icon.
- How to use oppattern.
- Adding a flip arrow.
- Adding a manipulator.
- How to use an array []
- How to transform.
- Simple boolean
Hey @franco_otaola507, great idea! Per your request, see the latest update:
Update!
- Colors now default to white.
- Optional check box for randomizing colors. (This is set to "Remember previous value", so that once you use it, it will remember your preferences for future use with this feature.)
https://cad.onshape.com/documents/85185b4d4f5b3e85f3094895/w/771f77c2109cca907aca7278...Learn more about the Gospel of Christ ( Here )
would you think in doing something like this for extrusion? with all its options?
@franco_otaola507, there is already an Extrude Separate by @Jake_Rosenfeld.
When you say "with all its options", do you mean the latest extrude feature or the options in my Sweep separate feature?
one last request if you could add this capability to 'offset surface' I would really appreciate it, as at the moment if fuses the surfaces together to give only one, something like 'offset surface Separate'
@franco_otaola507, this is as separate as solid bodies can be. Are you trying to create surfaces instead? What is your end goal?
I meant that when using offset surface tool, with two different surfaces that are one next to each other, it will create only one surface. for example if you use 0 as offset, the result would look like if you fused the two surfaces. for example if you use extrude separately and then select two faces it will create only one surface instead of two
@franco_otaola507
Hm, you could always sweep them as solids, then delete the end faces to create the surfaces. I'm still not quite sure your end goal. Could you share a part studio of what you are trying to do?
I also use Profile Sweeper custom feature. It can sweep multiple parts, without having to create a seperate sketch for circular profiles:
Profile Sweeper FS (Reese) | Profile Sweeper
