Ramping up for production project - what's needed...
caradon
OS Professional, Mentor Posts: 300 PRO
I am about to start a project that would be an ideal case to test productivity improvements with Onshape vs SW>Parasolid>mail>SW>etc.
Here is a list of currently missing functionalities that would be of great value during this project:
Any thoughts?
EDIT 26/01/2015, 23:30 CET:
Added request for feature patterns.
Regards,
Dries
- a markup documentation/annotation tool: this could be either 3D markup in model space or 2D drawings. At least some way to put comments in CAD space and not just as a PDF in a separate tab.
- Extrusion vector: I know you can get the same behavior with sweep, but I would like to do this in a single feature.
- More options for extrusions: offset (from surface), bidirectional...
- Part Studio equations: driven dimensions (!), relating feature dimensions to sketches... Pretty essential for most models I do.
- Cut with surface: again, I know it can be done through splitting & deleting bodies, but I would like a single feature.
- Feature tree organization: Folders! Folders! I can't stress enough how desperately I want better organization of the tree. Folders would be a great start, but there are other things too: feature icons, body/part relations, parent/child relations...
- Feature patterns: face patterns are cool, but feature patterns would be more robust
Any thoughts?
Regards,
Dries
On the surface cut have you tried using the replace face with any success, would this do the same thing? I have not used it yet but also would very rarely use a surface cut and may be barking up the wrong tree for you here.
Twitter: @onshapetricks & @babart1977
Or maybe Onshape is putting together a much more powerful solution. Some designers (I've met) have a hard time grasping the concept of 'cutting with surface'.
Dries
I was intrigued by the demonstration last week from Microsoft showing inking in the browser. This would be cool with something like markup capabilities in Onshape. I hope other browsers will support inking as well. Document approval via a signature via a stylus would be cool... A paperless system with electronic inking would be nice.
LearnOnshape facebook group
Definitely need feature patterns. Added to my original list.
Dries
Dries
I would agree with you to some extent. I have fond after using the 'create selection' tools on the right click you can get quite proficient at it. It really comes down to OS being a new system and a new way of doing things. Once you adapt it can be quite smooth. That being said yes I agree that patterning features is a pain and could use some tweaking.
face pattern...select ALL faces to pattern...pattern
Face patterning works when you have faces linked to each other , or little self contained groups. But feature patterning works because it creates new geometry regardless of faces. Bottom line is click numbers. Features need less clicking than faces. Especially on mobile platforms.
