Keyboard shortcuts, Have you found them?
lougallo
Member, Moderator, Onshape Employees, Developers Posts: 2,002
If you are like me and use keyboard shortcuts a lot, hopefully you have found our keyboard shortcuts map. Ultimately we are going to be looking at customization in the future, however currently we have a set of keyboard shortcuts that can speed up your Onshape experience!
Like most web applications, you can hit '?' (shift+the '?/' key) when in a document to show the keyboard shortcuts map quickly. Hit '?' again to dismiss it or click anywhere outside the map. If you like to have them displayed as a reference, clicking the pop-out icon (angled arrow in the upper right) will open the map in a new browser window. You can also access this from the ? menu in the upper right by clicking on "Keyboard shortcuts".
The shortcuts change based on where you are in Onshape (i.e. sketching, Part Studio, Assemblies). Here are a few of my favorite:
- (p) hide/show planes
- (n) normal to
- (shift + s) save a version
- (s) New sketch
- (e) Extrude
- (r) Rovolve
- (p) New Plane
Part Studio:
- (l) line
- (c) circle
- (r) rectangle (whichever one is active)
- (d) dimension
- (e) equal relation
- (t) tangent relation
- (i) coincident
Sketching:
- (m) mate (launches it in Fixed but you can change it)
Assembly:
- Select a face
- Hit n (normal to)
- Hit s (New sketch)
- Hit r or c or l (new rectangle or circle or line)
- Hit d (dimension)
Some unsolicited comments: I use shortcuts to speed up my work. As with touch typing there are significant speed benefits if you don't have to look at the keyboard. I always set up my shortcut keys so that they are usable by my left hand without looking and my right hand never leaves the mouse. (the mouse typically has Enter mapped to a button)
I only map the most used commands for any given mode (sketch, part, assy), adding commands as I notice I'm repeating them often.
I'm looking forward to being able to set my own shortcuts. Meanwhile I can use a programmable keypad.
The only one that I would redefine is isometric (shift 7), I use this one a lot and yet it's the hardest one to hit.
BTW, there is a little bug when you click open the keyboard shortcuts... it shows the shortcuts for the drawings for a quick second!
Linked[in]
Linked[in]
(*) Btw, best wishes to all of you! (*)
Dries
I have set a virtual keyboard using an ipad app called Keypad. It links up to VNC server running on my PC ( Apple and Linux supported). See http://keypad.iosproapps.com/
and https://www.realvnc.com/
I have set up a multi screen arrangement which seams to work nicely except for the missing shortcuts!
I'm happy so share this configuration but it is not complete yet so it might be better to lobby for more shortcuts first!.
Here are some screen shots. I have included all icons but not all are active.
The top row are the page selectors. Haven't decided what to do with feature script yet.
I hope I haven't upset any copyright. Let me know what you think.
