Keyboard shortcuts, Have you found them?
lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
If you are like me and use keyboard shortcuts a lot, hopefully you have found our keyboard shortcuts map. Ultimately we are going to be looking at customization in the future, however currently we have a set of keyboard shortcuts that can speed up your Onshape experience!
Like most web applications, you can hit '?' (shift+the '?/' key) when in a document to show the keyboard shortcuts map quickly. Hit '?' again to dismiss it or click anywhere outside the map. If you like to have them displayed as a reference, clicking the pop-out icon (angled arrow in the upper right) will open the map in a new browser window. You can also access this from the ? menu in the upper right by clicking on "Keyboard shortcuts".
The shortcuts change based on where you are in Onshape (i.e. sketching, Part Studio, Assemblies). Here are a few of my favorite:
  • (p) hide/show planes
  • (n) normal to
  • (shift + s) save a version
    Part Studio:
  • (s) New sketch
  • (e) Extrude
  • (r) Rovolve
  • (p) New Plane
    Sketching:
  • (l) line
  • (c) circle
  • (r) rectangle (whichever one is active)
  • (d) dimension
  • (e) equal relation
  • (t) tangent relation
  • (i) coincident
    Assembly:
  • (m) mate (launches it in Fixed but you can change it)
This makes it incredibly fast. Here is my common workflow:
  1. Select a face
  2. Hit n (normal to)
  3. Hit s (New sketch)
  4. Hit r or c or l (new rectangle or circle or line)
  5. Hit d (dimension)
    Yay! Shortcuts! I love 'em.
    Some unsolicited comments: I use shortcuts to speed up my work. As with touch typing there are significant speed benefits if you don't have to look at the keyboard. I always set up my shortcut keys so that they are usable by my left hand without looking and my right hand never leaves the mouse. (the mouse typically has Enter mapped to a button)
    I only map the most used commands for any given mode (sketch, part, assy), adding commands as I notice I'm repeating them often.
    I'm looking forward to being able to set my own shortcuts. Meanwhile I can use a programmable keypad.
    Yes, learning a few keyboard shortcuts allows you to fly through a design.
    The only one that I would redefine is isometric (shift 7), I use this one a lot and yet it's the hardest one to hit.
    @LouGallo‌ Thanks for sharing the list and the way to get to it in Onshape. I see there is a zoom to fit command (f). Any thoughts on making this map to the double middle mouse click? I use this all the time in SolidWorks, DraftSight, and AutoCAD.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @PDY‌ It might come as an option in the future. I don't have a middle mouse click on my mouse! Anyway you can also right click Zoom to fit...
    I use N & F a lot, but I forgot about the shortcuts for the dimensions & constraints! Sweet.
    BTW, there is a little bug when you click open the keyboard shortcuts... it shows the shortcuts for the drawings for a quick second! :smiley:
    Easy Fix for that one, unlock drawings..  ;)
    Spacebar to clear selection is one that I use all the time.
  • stevehessstevehess Moderator, Onshape Employees, Developers Posts: 98 image
    @FastwayJim‌ - we fixed the temp display of drawing keys.  You'll see them soon..... promise.
    Steve Hess \ Onshape Inc.
    Haha! I chuckled when I saw that, @SteveHess... Can't wait!
    edited December 2014
    What about as a Christmas gift?
    (*) Btw, best wishes to all of you! (*)
    Dries
    And to all of you.   It's been a great year and looking forward to rocking the CAD world in 2015.
  • Franz_Eric_SchneiderFranz_Eric_Schneider Member Posts: 1
    It will be great when shortcuts are changeable. There's some things I do a lot that wish were a shortcut, in this case toggle construction lines.
  • adrian_traceadrian_trace Member Posts: 5 ✭✭
    Changeable shortcuts will only help me if the process allows shortcuts to be set for those that are currently omitted.
    I have set a virtual  keyboard using an ipad app called Keypad. It links up to VNC server running on my PC ( Apple and Linux supported). See http://keypad.iosproapps.com/
    and https://www.realvnc.com/
    I have set up a multi screen arrangement which seams to work nicely except for the missing shortcuts!
    I'm happy so share this configuration but it is not complete yet so it might be better to lobby for more shortcuts first!.
    Here are some screen shots. I have included all icons but not all are active.
    The top row are the page selectors. Haven't decided what to do with feature script yet.
    I hope I haven't upset any copyright. Let me know what you think.
