slow response
I am connected to the NBN broadband in Australia over a fixed wireless system and getting very good speeds, averaging 47 Mbps download and 13 Mbps upload.
Butt it takes so long to do anything in onshape nothing like what I see in the tutorials.
I have to what a few quite a few seconds at least between clicks.
Wondering if there would be any suggestions or am I just out of luck with this type of internet connection.
I hope these issues will be solved once they come up with their final product.
Please can you open up support tickets so we can investigate?
- Show the connection console using Ctrl+D. This displays your connected server and ping time.
- From the Help downdown select Feedback and let us know your geographical location and what you were doing.
- If you are only experiencing this on a specific document please share that with support.
You can hide the console with Ctrl+D again.
Many thanks,
Andy
Did you remove the CTRL+D shortcut to connection console? All I get is new bookmarks..
I'm running a virtual environment on a small computer and have noticed degraded performance if I get too much stuff going on. If I clean things up, the performance bounces back.
Crtl+D isn't working for me on a MAC, but refreshing the tab brought it back, thanks 3dcad.
To get a better idea of what is happening I have been watching "System Monitor" (Ubuntu Linux but I suspect similar utilities are available for Apple and MS systems.) which graphically shows the activity of each CPU core, memory & swap use and network send/receive activity. FWIW, here's what I typically see on my 25MB down/5MB up Comcast Internet connection using my 8 core Xeon HP workstation with 32GB of memory and a Quadro 4000 GPU running Chrome or Opera.
When I click on a tab to load a complex assembly (95MB), I see the outgoing request which is followed about 6 seconds later by the first of three short "surges" of incoming data. Each surge follows the previous one by 3-5 seconds and each is about twice the size of the previous one. The whole 95MB file downloads in less than 10 seconds which is pretty good. The same file loads from the HD in about the same time with a local CAD application. A faster Internet connection wouldn't make much difference.
Upon the arrival of the 1st surge, CPU activity picks up with what I call "serial multi-threading" where each of the 8 cores maxes out at 100% for 10 - 20 seconds in rotation. This is probably the system spreading the heat load while running one single-thread task. As the model appears on the browser screen, the CPU core activity becomes multi-threaded with all 8 cores sharing the load roughly equally. CPU activity continues at this clip for about 20 seconds after the OnShape "twirlie" disappears. The memory/swap usage remains unchanged at 4.0 GB. The 3-surge receive and CPU load pattern is the same with Insert.
I'm not sure what all this means except I probably don't need 32GB of RAM but a faster CPU would be nice. More GPU horsepower would be nice too but I can twirl my biggest assembly around the screen with very few hitches however, round shapes take on a poly-angular appearance which is my biggest gripe. More robust use of multi-threading by browsers would be very helpful.
https://cad.onshape.com/documents/c906a6bdcf50136ee9dbb9e1/w/9f6d794f5ac613eb6ba6aa67/e/53e2bc55b9b26c943174b00e
Chrome choked and essentially died. Opera kept chugging and got the job done - eventually. I'd guess Opera was 20% faster than Chrome. The biggest delay was inserting and grouping the 11, 15s6p sub-assemblies. Modeling a large pack makes it easy to see why there's a big difference in cost between cells and packs as measured by $/kWh.
Either browsers have to adopt multi-threaded programing or I have to get a faster CPU.
No serious problems with chrome on thinkpad x1 yoga. Load time 1-2min, viewing slightly joggy but manageable, selection takes 2-3sec to perform..
In my experience this would run perfectly with decent office pc.
https://cad.onshape.com/documents/c906a6bdcf50136ee9dbb9e1/w/9f6d794f5ac613eb6ba6aa67/e/5ed223994e0b3956b544c456
