dwg conversions
I have gotten my design recreated in OnShape (http://www.spiked3.com/?p=3651) and I still have not found a vendor even in the ball park on price of my current vendor who can not open dxf files beyond 2004. And that is not even considering his convenience of having all materials in stock, and usually 2 day turn around . To give you an idea, the last laser cut set of acrylic from him was $40 shipped for materials, labor, laser cutting. I had an estimate where I bring the materials myself, do the labor, and the laser time would only be $132 at the local make space. Yeah, not going to happen. Everything else I have seen online is more expensive.
So I am looking for a converter for my dwg files from Onshape to older versions. I tried the Autocad thing that supposedly does it. It first popped up a warning it was a file not created by Autocad software, then displayed a blank. Is this because they are only converting their own files, or does it truly not understand the file? I have not seen anything else, that was not ridiculously priced. I have not tried any of the online services yet either, as I really have to be desperate (which I almost am now) to trade the resulting spam headache for what is a simple version conversion.
Mike Partain aka Spiked3
pete_yodis OS Professional, Mentor Posts: 666 ✭✭✭
@Spiked3 DraftSight... http://www.3ds.com/products-services/draftsight-cad-software/offerings/
It's free and quite good. It should allow you to save forward and backward. WIndows, MAC, Linux.
5
an acad 9 format. It's lines, circles (can you believe it-crazy), arcs how hard is that?
I guess I am glad a never dealt with these guys (dassault) before.
On to look at Nanocad now.
their free license is one year renewable and the last time I had to register it wasn't working. by giving them all the infos, they solved the problem immediately..
Fred
Please let us know if this meets your needs, and what else we can do to improve it.
@Jon McIntyre : Yay !
In general, it seems to me the ideal solution to a problem is the one that makes it go away, rather than the ones which fix it after the fact.
Subtract, rather than add.
DWG export is (to my way of thinking) an entirely separate question, and there I think a range of choices will be necessary.
I guess it should be eminently feasible for a single engine to import any dwg version (certainly any dxf version), in which case there is no problem in that direction.
For Solidworks, as with dwg, would be great to have one of the export version options which is as early as possible, because any later version will read it. (Speaking selfishly, at least earlier than 2009 !)
BTW, indeed NanoCAD was a very nice program, no hassles. If I had a use for something AutoCAD llke, it looks like it would do a nice job. When I recently upgraded my desktop I didn't even bother installing anything else (Alibre or DraftSight). And since the OS DXF files are now an earlier version format I should no longer have the need for anything 2D anyhow.
I use DraftSight for my daily job, its really great. If you activate it, you will just get some newsletters, thats all. And every year you have to reactivate it. If you don't like to get newsletters on your primary eMail adress, just use another one. After activation you will get an eMail with a link and then its done.
best regards
martin
frédéric, NanoCAD was immensely better in the small amount of time I used it. I did re-install it on the new machine, even though I have no immediate need to use it.
