Tips and tricks 2017
2»
    Quick tip.
    When doing an extrude like "to to face", select the face you're going to extrude (but don't go into the command yet), spin your view around so you can see the target face you want you extrude to go to THEN go into the extrude command (shift+e).  Now you can select the target right away.
     You'll find in larger assemblies once you're in the command your view movement gets a slower and it's difficult to find your target.
    I just noticed, on accident, that when you RMB the rotate translate symbol you get a 90 & 180 option.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,959 PRO
    Oh snap! Tottaly missed that @Tony_C_
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
    It's not hard to totally miss stuff, I only just realized that that transform by line also works point to point. I have been going to the effort of using transform by mate connectors and even doing a sketch with a line on it when the simple solution was just select 2 points. I think the description transform by line had lead me astray.
    It's also easy to forget features you don't need that often.. I suppose Onshape is not a new born baby anymore =)
    Right clicking on a dimension in a sketch can change it from a drive to a driven dimension.
    I just found this out....
    edited October 2018
    Using Onshape across monitors can be handy if screen gets crowded (and you get plenty of room for custom features =) )
    This can also make nice screenshots of wide stuff
    In windows, you need to drag manually to total wide, then snap top of monitor to get full screen.
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,059 ✭✭✭✭✭
    Woops, accidentally posted to old thread..
    Well, years go by so fast that it's just impossible to keep up - it's almost 2019 already and getting ready for 2020  :#
    @3dcad
    Maybe you should just make a thread called "Tips and Tricks", and not have a year on it.
    From the time when you needed different tricks and workarounds for many things that were later implemented as standard features..
