How to print a sketch with dimensions on it?
martin_olesen
Member Posts: 24 ✭✭
Hello, i have tried to print out one of the sketc from one of my projects, but i find it very difficult.
I did find a way where i right click on the sketch plane, and then choose print, it work, i do get a sketch with the dimensions on it, but the font of the dimension numbers are extremely small.....do i do this wrong, is there another way to print out sketches with all the dimensions from Onshape?
You can also show dimensions with double-click on any sketch geometry in model area.
And to answer your question, yes it is still an issue - dimensions appear very small in print.
Or Export as DXF/DWG
When crawling through Onshape forums, always look at the date stamp on last post and then goto 'New in Onshape' and look if there has been update to certain matter. Onshape gets better every three weeks.
For example here, my last post from Nov 2017; there has been more than 20 updates since. Some of these have decreased the need to print sketches by improving drawings and that's why this thread has disappeared in history..
@mario_darceuil
@3dcad
@martin_olesen
Their print function seems to be rendering a high-resolution view, scaling all the line-thicknesses down and also the dimension text.
If you print using a small page size such as A6, it won't be as high resolution and you can scale it up again in the browser's print dialog
