Improvements to Onshape - April 6, 2015
lougallo
Member, Moderator, Onshape Employees, Developers Posts: 2,001
First I would like to thank all of you that have joined our Beta over the past month and submitted feedback to us. This week we are launching some new functionality around assembly mating, sketching and a few other sharing and subscription updates. Let's take a look!
Highlights include:
Highlights include:
- Offset option for Fastened, Slider, Planar, Revolute and Pin/Slot mates (distance)
- Screw/Linear relations
- Driven dimensions (will automatically show greyed if driven and can be switched in the context menu.
- Add/delete spline points (deletion is done by selecting the point and hitting Delete on the keyboard)
- Adding or duplicating tabs now places the new tab next to the current/active tab (used to add it to the end..)
- Remove yourself from a shared document
- Reactivate a canceled subscription
Dave
Ariel, WA
Cool!
Now I can bet what OnShape will do come April 1st...
@owen_sparks
Or make it say: "Error: Onshape has crashed. Reason: Filesystem not found"
