Tips and tricks 2018
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
To begin with, check tips & tricks 2017
https://forum.onshape.com/discussion/5936/tips-and-tricks-2017
Please add any new shortcuts, hidden features and usability inventions here
Remember to bookmark
page since forum rolls out pretty quickly these days!
1. Open Onshape main page (or whatever you wan't to land) into Chrome.
2. Hit three dots on top right to open menu --> More tools --> Add to desktop
3. Check 'Open as window' on confirm dialog and Onshape will open without normal browser menus and provide more room for modeling!
4. You will find nice Onshape icon on your desktop which you can drag to quick launch toolbar
If you have some documents you need to access often, repeat this while document is open and drag shortcut under Onshape in toolbar, you will have quick access using RMB on quick launch logo.
Same procedure works for any webpage (sheets, docs, erp)
This still works because you can select edges in that mode.
Now you can modify all of the parts in a studio at once without having to go thru the full document in "workspace properties"
/* Hint, bulk rename in part studio */
You can also right-click on the Part Studio tab, select properties, then expand using the arrow in the dialog
Includes mates
Only works in the same browser tab.
If you create the shortcut, you can then go into your chrome apps and right click, and click "Open as window"
That is it! I searched Internet 1/2 hour and could not find. I just had to recreate the shortcuts from the Chrome Apps. Thank you!!
A quick way to get all the edges of a face is to hit "use" first then window select from the side.
If you wanted to select all the vertical edges (if you wanted to fillet them, etc.), you can select right to left over the vertical edges
