What’s New in Onshape’s Latest Update (September 7th, 2018)
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
Hot on the heels of our previous release just two and a half weeks ago, here is another! Keep those improvement requests coming and enjoy these updates!
CAD IMPROVEMENTS
NEW GRIP POINT TYPES IN DRAWINGS
You will now see different types of grip points in Onshape’s drawings to indicate different actions. There are now closed-circles for moving grip points, squares for resizing, hollow circles for rotating, and diamond grip points for flipping.
AUTOMATICALLY CREATE A VERSION AFTER IMPORT COMPLETES
Users can now quickly reference imported data because Onshape automatically creates a version after importing from the documents page. This not only creates a referenceable point in time for the original imported data, but also streamlines the process for bringing data into Onshape for immediate use in projects.
Note: Newly imported data will appear at the top of the ‘Created by me’ section in the insert dialog.
ADDITIONAL BALLOON SHAPES
Onshape now has an expanded selection of balloon shapes for the callout dialog. The expanded choices will be helpful for various drawing applications such as inspection drawings.
When in the callout dialog, the shape dropdown is listed alphabetically revealing the new options available. Adding flag notes, revision triangles, and more can be accomplished through the callout dialog.
COMPATIBILITY CHECK PAGE IMPROVEMENTS
The Onshape compatibility check page has been improved to indicate the platform, browser, and browser version you are using. It will highlight which of these items we don’t support and even provide a suggestion on how to get to a supported environment; whether it be sending you to an update page for your current browser or suggesting one of our native mobile applications.
AUTOCOMPLETE FOR FEATURESCRIPT LOCAL VARIABLES
Developers will now be able to use autocomplete for local variables in FeatureScript. After creating a variable or function, the next time a user starts to type that name they will see it as an option for autocompletion just as with Onshape’s FeatureScript standard Library.
ADDITIONS TO STANDARD CONTENT
We have added standard content for DIN, ANSI, and ISO pins as well as DIN and ANSI retaining rings. To view the list of newly added standard components and submit requests for additional hardware please reference this forum post.
MOBILE IMPROVEMENTS
SHEET METAL TOOLS FOR IOS
Onshape’s IOS application now supports sheet metal tools. Don’t forget to take advantage of the precision selector on edges and corners.
PROFESSIONAL FEATURES
REVISION LABEL ON RELEASED PARTS WHEN VIEWING A VERSION
You will now see labels indicating which items of a document are released when viewing a version that contains released items. This will streamline the navigation of versions for released items instead of having to go to the release package.
ENTERPRISE FEATURES
GETTING STARTED GUIDE FOR LIGHT USERS
When a Light user is added to an enterprise account, they will be greeted in Onshape with a message describing their permissions, as well as a getting started guide for navigating and using Onshape. The ‘Getting Started as a Light User’ guide for enterprise can be found here in the help.
Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the Onshape Changelog.
Having recently spent the most time using drawing functionality, it's great to see the enhancements coming.
LOVE THE UX with the Grip behaviors - well done! These subtle things are HUGE, daily usability boosters that make the software more enjoyable to use.
I'll get to the balloon's soon too.
- Automatically Create A Version After Import Completes
Hey, so if we use the original version, it will help us with those complex files and not have to rebuild it right? That helps for those pile of trash files that are all surfaces and take forever to process.The sheetmetal in IOS... now THAT is cool !
Bravo, thank you once again. Nice job.
I really like the featurescript variable autocomplete!
How do I view a SM flat pattern on mobile though?
Moar balloons!
Local Variable autocomplete... sweet
hi guys,
Can you please tell me where I can find the changelog about "section view performance"?
Sorry I didn't find any information about it but got a bug in onshape today.
I found that some imported parts will be missing in the new created section view.
It looks like a "section depth" function was added, but I don't understand the new rule.
somebody got the same problem?
https://cad.onshape.com/documents/2006e4ac894982c254848bb9/w/3b09f1312c88a40618632678/e/f4ab6fd5e6f2e25e041248b3
@pete_yodis
The drawing with a lot of quotes becomes a real mess.
That is the down side of "Always being up to date" if something isn't working the same anymore. You can't even go back and check old behavior. You have to rely on your gut memory.
We are talking about the grips that used to be where the red dots are drawn below.
We used to use these very often to align our dimensions. It was very obvious when they were removed. No gut required
Gotcha! Thank you.
Sorry for misunderstanding. There is no "section depth" option, and I found the bug has been fixed today.
However, I still waiting for a "section depth" option cause it will help a lot in my drawings.
This was an oversight on our part and we have pushed a new update this morning that brings these back. Please let us know if there are any other issues.
Seriously it is.
A few months ago some of our SolidWorks customers received an email from their reseller indicating that there were errors in the last SolidWorks Service Pack.
The reseller recommended not to install that service pack... and customers who had already installed it would had to wait "ONLY A FEW DAYS" (actually more than a week >:) ) for a new service pack.
As a programmer, finding a bug like this in production is a kick in the ass but with systems like Git (something very similar to the revisions and branches management in Onshape) you can handle it much better.
So that explains why Git was worth $7.5 Billion to Microsoft... it must work some magic!
https://www.theverge.com/2018/6/4/17422788/microsoft-github-acquisition-official-deal
Microsoft bought GitHub, which is the largest host of source code in the world, but git itself is FOSS (free and open source software).
