For instance.
There are some cases where I had to create a feature on a co workers computer because it would not extrude remove from the assembly level on my machine. As long as i dont edit the feature on mine it would stick.
Or my favorite: part properties delete a random property at random during a regen or save... have a button on my mouse that i can open and close the property window 3 times to see if the property actually stuck.
Apparently 2
LoL, the new version of SW broke all his models...
Now he has to spend a few hours fixing his sh#&
This time it looks like my computer forgets menu options now and then...
It still changes the position of a couple drop down menus, so i have to go to customize, unlock the toolbar, move the menu, go back and lock the tool bar again (same problem since 2017)
So this version they decided to hide the customize button randomly...
here is the problem: display state got moved up and it is taking up screen area..
Hmm, customize should be here
Lost a screen shot where the button was missing from the options fly-out.. I'll edit this post later when it happens again (3rd time it's happened, i'm on second day using it, I'm sure it will happen soon)
Now I opened another part file
and now it shows up
Now I crtl+tab back to the other file and its there now XD
Now I can fix the original issue
**grumble grumble**
Onshape Dev Team:
Yellow are the fields I edited, red are the props deleted..
did a double check 2 more times and filled them back in.
each time fewer and fewer deleted, eventually I opened the screen record to show, and it ended up just deleting one that time... what utter garbage
SolidWorks:
Onshape:
at least all the parts are there in OS
Look what I'm having to do:
OMG, this seems so un-necessary.
The main problem with sketch image is that you can't carry it into assembly..
My 'W' & "V" keys are right next to each other, so I accidentally hit ctrl+W instead of ctrl+V and it closed out the web browser...
Usually when I'm working in SW if I'm plugging away and I all of the sudden see my desktop, My blood turns white.
So I had the same reaction for a sec, then remembered, Oh yea, nothing to save.
Open it back up and I am right where I left off. Yeay Cloud!
More bugs than improvements.. per usual.
I can't even mate to this face anymore. Need to make a dimension mate from the far face and offset the thickness of the sheet metal... so much for parametric modeling...
What a F(*&ing joke
