https://www.boltscience.com/pages/helicalspringwashers.htm
https://engineerdog.com/2015/01/11/10-tricks-engineers-need-to-know-about-fasteners/
So they are still needed unfortunately..
Yes I strongly agree.
It sucks having to go dig through all of the standards.
Even in solidworks I made a common directory (which is literally short-cuts to the same folders shown below)
To get what I need faster.
I know it's a little too late to change Onshape's insert now BUT
this is how we sorted it in SW. It is very intuitive and quick to find anything (at least for humble old me 😜)
- Inch or Metric
- Type
- Standard (ISO/DIN etc.)
- Size (in configurations)
like
Is like to request a toggle option to only display hardware I've previously used as that means it'll be available from my stores, wouldn't require new pn, and avoids the associated winging from our shopping dept...
"Ansi Hex Cap Screw"
And it would switch the drop downs to:
ANSI Inch
Bolts & Screws
Hex Bolts
Hex Cap Screw
From there you will only need to size it up and insert.
The "OR" I was attempting to show the favorite reading your description / part number. But in hind sight. I think it would be better to give the favorite a new name on creation. something we can label shorter. In this case i'd call it HHCS (in)
Surfacing company content/favorites would be very useful as at the moment it kind of gets lost.
One area I have trouble is long bolts, I understand we can not have continual sizes over standard lengths but I regularly use long bolts and lots are commercially available, I would like a way to create in the back end of the standard so it surfaces for a company rather than having to model myself outside the content.
I'd also like more flexible to interchange content while maintaining mates, ie metric to imperial bolts.
And for six sided bolts, cheese head screws and nuts down to M1 please.
Also found this improvement request, please vote so we can get some attention focused on content to make it a complete solution. https://forum.onshape.com/discussion/12046/custom-standard-content
Room for improvement:
1. Within ANSI Inch > Bolt & screws > Machine screws... there are differences from Round head machine screw to Pan head machine screw
ISO Standard has a different structure to the Standard content (see image 4)
2. "HEAD TYPE" has inconsistency:
Sometimes Type I, Type IA (image 1 or image 3)
Other times Slot, PH, PZ etc (image 2) is used -- this is preferred for my team
3. The preview of the head type does not match the "HEAD TYPE" selections (image 2 or image 3).
Data accuracy / data consistency would go a long way for a more intuitive user experience.
ISO
Also, metric nylon screws would be a good addition.
Other requests are:
DIN 7982
DIN 988
ISO 14583 in M3x14
Maybe also DIN 9021 or ISO 7093 washers.
Twitter: @BryanLAGdesign
See the list in https://cad.onshape.com/help/Content/standard_content_appx.htm?Highlight=prevailing
