Twitter: @BryanLAGdesign
Please, Please, Please Onshape, make it so we can build our own libraries, rather than a standards library! Personally, I want a commercial or company library with parts that adhere to standards but listed by and searchable the same as where they are bought or stored in the company listings. The Insert tools work great but listings of parts are so painful.
Thanks
What about a library of O'rings
Thanks for pointing that out, I tend to keep my nose in ansi in. And forget that there is so much more.
I need some kind of lock nut in inch standard ???
but things like distorted thread nuts can be faked by selecting another material really and filling in the description.
I know that can be done, it just irritates my OCD.
Also if I am not mistaken that sticks with that fastener and you need to remember to reset it the next time you use it. I may be wrong.
Then Onshape implemented it, and I was like, "Oh man, this is cool, but I feel pity for the poor fool who will have to update this every time someone needs a nut or bolt"
Kudos for Onshape doing our work for us, but there are still a lot of missing pieces left to go.
Like Lock washers for Metric, apparently, they don't exist in ISO, so I have to swap to DIN, then back to ISO. The little quirks that for the longest time I didn't even know were a thing and went without standard content lock washers for the first few jobs because I didn't know they were hidden in another standard. Most of the time I just want the most generic, common, cheapest, most available fastener. I'm actually learning a lot about fasteners that is mostly irrelevant for the low end engineering we do here.
I still like the simplicity of our fastener library in SW:
I somewhat agree with the comments. However, who has the time or wants to make and manage their own libraries, if there is an easier or better way I'll take it.
Then you have the issue of different companies needing different custom properties etc... So it's hard to come up with something generic enough.
You could "derive in" from a public library of documents but that brings a bunch of overhead... Hopefully in time you'll see companies provide "native" Onshape 3D cad but "neutral" (i.e. STEP, IGES, etc...) are here to stay as they work (although not that well...) across multiple cad systems.
Hopefully there are some updates coming which expand the standard hardware.
Cage Nuts and Rivets would be fantastic.
The aerospace industry needs AN/MS hardware - bolts, nuts, and hydraulic fittings. Some of this is in McMaster Carr, but a lot isn't.
@Jason_S
Smaller HEX head screw grade A & B DIN EN 24017 would be great - like be sizes marked below. I cannot find anything smaller than M1,6 in the Standard Content Library.
Regards
Kristoffer
To me one of the most gaping holes in here is the lack of any standoffs in any of the standards. I think the idea of bringing in McMaster Carr would be great, as well as libraries that you can share. It has been brought up that people still need to put in work for that, but since some people themselves talk about maintaining libraries, I think that this would allow us all to benefit off each others work.
