Improvements to Onshape - June 3rd, 2020
NeilCooke
Moderator, Onshape Employees Posts: 5,942
I can imagine that one or two of you will be pleased with this latest update which includes the most requested and voted for feature in the history of Onshape. Enjoy!
Face colors may also be assigned programmatically with FeatureScript using the setProperty option "allowFaces":
CAD IMPROVEMENTS
FACE COLORS
Appearances can now be added to Solid and Surface Faces in a Part Studio. The new Appearance Panel displays all currently assigned Part and Face colors which can be edited, renamed, configured and suppressed.Face colors may also be assigned programmatically with FeatureScript using the setProperty option "allowFaces":
setProperty(context, { "entities" : faceQuery,
"propertyType" : PropertyType.APPEARANCE,
"value" : color(r,g,b,a),
"allowFaces" : true });Face colors set by Custom Features do not appear in the Appearance Panel.ISOLATE KEYBOARD SHORTCUT
Parts in Part Studios and Instances in Assemblies can now be quickly shown in Isolate mode with a new keyboard shortcut. Hover your mouse over the required Part or Instance in the graphics area or make a selection from the Parts list or Instance list then press Shift + i.NORMAL TO NEAREST DEFAULT PLANE
The keyboard shortcut for View Normal To (n) will now rotate the model view, when no geometry is selected or highlighted, to be normal to the nearest default Plane. Pressing n while hovering over a planar face also now works as a shortcut for viewing a model normal to a face.FEATURESCRIPT CUSTOM TABLES
Calculation results, measurements, lists, properties and other types of data can now be easily extracted from a Part Studio and presented in tabular form using Custom Tables. For Enterprise accounts, any Table that the administrator adds will appear in all Documents for all members that have "Link" access to the Table. Documentation for Tables can be found here.HOLE TABLES IN PART STUDIOS
When a Hole feature is created in a Part Studio, a new tab appears on the right that details the specification, quantity and tag for every Hole.SHOW HIDDEN BODIES DURING EDIT
Hidden items in the Parts List such as Curves, Surfaces and Parts will now show automatically if the feature that created them is being edited.DELETE FACE / DELETE PART
The Delete Face feature, with the Leave Open option selected, is now able to delete an entire Part or Surface without having to create an additional Delete Part feature.PERFORMANCE IMPROVEMENTS
Notable performance improvements that may affect your daily workflow include:- Faster retrieval of metadata such as Part properties.
- Faster opening of Documents with Part Studios containing lots of Derived Parts.
- Faster opening of Documents containing Custom Features that reference older versions of the FeatureScript library.
- Faster Assembly Configuration changes requested via the API.
PROFESSIONAL IMPROVEMENTS
PENDING APPROVALS IN OTHER RELEASE CANDIDATES
A new release condition has been added to Release Management that prevents an item from entering a release workflow if its Part Number has been used in another Release Candidate. If this condition is not set, a warning will be shown in the Release Candidate dialog, but the item will be permitted to enter the workflow.ENTERPRISE IMPROVEMENTS
INVITE USERS BY CSV FILE
Enterprise Administrators can now invite large numbers of users by importing their details from a CSV file. A sample CSV file is provided and automated error checking ensures all imported details are valid and correct.SAVE DASHBOARD FAVORITES
Onshape Enterprise's Reports and Analytics can now be saved, along with any filters, for quick retrieval later. All saved dashboards are listed in the My Analytics filter and can be accessed by any user with permissions.LEARNING CENTER IMPROVEMENTS
NAVIGATING ONSHAPE FOR NEW USERS
A new technical briefing has been added to the Learning Center to help users unfamiliar with Onshape to navigate a Document they have been shared into: Navigating Onshape for New Users. No sign in or Onshape account is required to access this technical briefing, so please feel free to share with everybody!Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
15
Colored faces! Featurescript Tables and Hole Tables... nice.
Also appreciate the New User content AND Analytics.
Thanks, I will test soon the FS custom tables
Face colors is going to be super helpful for use in Keyshot for me.
"n" to view normal to the closest cardinal plane is a bit of muscle memory I never lost switching from Solidworks 4+ years ago, so that's very welcome. Now when I hit "n" out of habit something will actually happen.
The custom tables seem very important too. Now I can probably phase out the Find Sharp Edges custom feature in favor of this.
Thanks! 👏👏👏
We will be using these right away.
chadstoltzfus@premiercb.com
There is so much here, are you sure you are going to have something 3 weeks from now
Very nice work all!
having trouble making a table though... what am I missing?
https://cad.onshape.com/documents/ae128fca39a1d825a3c5d427/w/3e80cca7399c99b775520d11/e/3068316aed3ce312a6d15462
return table("BOM", columns, rows);We are working on uploading some custom table samples right now which should help give an example of how the internals for tables work. They will be seen in the Custom table samples tag
Question: looks like custom tables only work in part studios and not assemblies? Unless I am missing it.
Still looking for a way to get mass properties of components out at the assembly level. Step in the right direction but does not quite solve that use case yet.
This is correct. Currently they are for Part Studios.
I saw that option, but the BOM search was coming up blank, so I gave it a go myself. It works fine now
It is unfortunate you can't have these tables for Assembly (yet?) then we could use them in drawings.
Good for a reporting tool, saves me from creating an assembly so I can read my custom properties that don't show up in the properties dialogue.
var matl = getProperty(context, { "entity" : part, "propertyType" : PropertyType.MATERIAL }).name; var weight = getProperty(context, { "entity" : part, "propertyType" : PropertyType.CUSTOM, "customPropertyId" : "5aad94f7b499a40f400c058f" // the ID of your mass property });Or you can set any value to the table
so weight doesn't "need" to read a property, so for example:
will always set the value of "weight" on each column to whatever you have here
so you should be able to evaluate the mass of each part in the loop
Something like:
var weight = evApproximateMassProperties(context, { "entities" : Part, "density" : Density * kilogram / meter ^ 3 });[EDIT] I see now - the label is created by splitting the face, then applying color to each face. Not applying an image (yet).
Also impressed with the document for new users. A very useful resource!
Great to see such a massive 'bedrock' improvement!
