Improvements to Onshape - July 31st 2020
Roy_Mutalik
Member, Onshape Employees Posts: 41
Our second release this month comes with a few features we hope will delight you. Let's take a look.
You can also edit the properties of the sub-assembly itself by right-clicking it in the instance list.
This propagation setting is referring to the number of workspaces directly above the version you are releasing from. The image below shows another example of a branched history.
This course is available to Standard, Professional, Enterprise, and Educational subscriptions.
A new edition of Onshape is now available designed specifically for education institutions. Onshape Education Enterprise includes features to allow schools and universities to easily manage permissions, control access, and understand activity and analytics in a tool designed specifically for students and educators.
It is important to note that Onshape's zero-cost Education Standard product, used by thousands of schools every day, will continue to exist with no changes. Education Enterprise is a premium edition available to organizations looking to solve these unique administrative needs at scale.
For more information on Education Enterprise, take a look at the Introducing Onshape Education Enterprise blog post, and please share it with any local schools or education programs you know of that may benefit from it!
You can also add parameter tooltips, visible by hovering over a field while using the custom feature.
Further documentation on these features is available here.
MASS PROPERTIES IMPROVEMENTS
You can now override the mass, center of mass, and mass moments of inertia of a part in the Part Studio. Simply check the "Override" box in the mass properties dialog and enter the new value. A new indicator for the center of mass is now shown in the graphics. The mass of a top-level assembly and composite part can also be overridden.
You can also now create materials with a custom density and apply them to parts on the fly using the new "custom" tab in the material dialog. These materials can be shown in the BOM and referenced in a drawing.
HIDE ALL FROM PARTS LIST
You can now hide all parts, surfaces, curves, or meshes in a single click in the parts list.EDIT PROPERTIES OF A PART FROM AN ASSEMBLY
You may now view and edit part-level properties directly from the assembly.You can also edit the properties of the sub-assembly itself by right-clicking it in the instance list.
VARIABLES RENAME EVERYWHERE
When renaming a variable, you now have the option to automatically update the name of the variable everywhere it is used.SECTION VIEW FROM CONTEXT MENU
You can now activate a section view from the right-click context menu of any plane, planar surface, cylindrical face, or mate connector.
RENAME DOCUMENTS IN-LINE
Documents are now renamed in-line from the Documents page.
Release Management Improvements
PART NUMBER PROPAGATES TO WORKSPACE ON RELEASE FROM VERSION
A new Release Management option has been introduced to allow you to control if part numbers should propagate to a workspace when releasing from a version.This propagation setting is referring to the number of workspaces directly above the version you are releasing from. The image below shows another example of a branched history.
- With "Never" selected, the part number will only be written in the version that is released.
- With "One Workspace" selected, releasing V1 will not propagate to Main or B1, as there are two workspaces above that version. However, releasing V2 will propagate the part number to B1.
- With "All Workspaces" selected, releasing V1 will propagate the part number to both Main and B1. Releasing V2 with this option would only propagate to B1.
Learning Center Improvements
INTRODUCTION TO SURFACING SELF-PACED COURSE
A new course, Introduction to Surfacing, has been added to the Learning Center to provide a fundamental understanding of surface modeling in Onshape. This course explores getting started with basic surfacing features to create complex part geometry.
Onshape Educational Plan Improvements
INTRODUCING: ONSHAPE EDUCATION ENTERPRISE
Onshape’s Education plans are the only CAD education platforms that fully support remote learning and teaching on any device, from any location, with zero IT footprint.A new edition of Onshape is now available designed specifically for education institutions. Onshape Education Enterprise includes features to allow schools and universities to easily manage permissions, control access, and understand activity and analytics in a tool designed specifically for students and educators.
FeatureScript Improvements
CUSTOM FEATURE DESCRIPTIONS AND TOOLTIPS
You can now set a description for your custom features, useful for capturing the features' purpose and workflow. This description is visible when hovering over the custom feature in the toolbar, as well as in the Feature Search (activated by Alt + C).
6
Custom Material , Section View, Edit Properties, Hide All are immediately useful to all users.
Nice Job !
Whew... if release management wasn't confusing enough lol....
So many little pain points I've had just went away. edit part properties from anywhere, center of mass, variable names (again), hide the "surfaces" folder. thanks!
I'm with you, John. I'm not sure what to make of this new decision I didn't know I needed to make. It's like a skydiving instructor asking what style of chute I'd like. I don't care to choose, I just want to live. Anyone care to explain the nuances?
Would also be great if the custom material was added to the library so it can be used for other parts and in other documents.
Hide all parts is excellent, I will be using this!
Edit Properties of part from assembly is awsome
Variable rename everywhere, this has been a frustration, this is a great improvement!
The mass and center of gravity editing on the mass properties is really good!
The variables and FeatureScript description improvements are also very useful.
This improvement just lets you do it on the fly.
As a band-aide while we wait for Onshape, you can also create a custom feature that sets the mass to a part and sets it to a custom property to be displayed in a drawing. I have one I can send your way if you want it. @Ben_Tek_Pac
Unfortunately you will still need to fill in the mass manually for assemblies ... Onshape really does need to address this issue. It is quite annoying to be honest.
And @Roy_Mutalik- I am really happy about these two:
Another scenario could be if two branches have different design approaches that both need to be tested. In some places, these would both need part numbers to order the prototypes and track them through procurement and testing, even if one is never actually used in production.
Not sure how common these scenarios would be, but I think its definitely possible and worth having the option.
If CAD were ranked by making things go away / come back; Onshape would beat all other CAD systems. Onshape is really good at this which makes things easier to design.
Twitter: @BryanLAGdesign
Mass Properties are moving in the right direction but I am looking forward to being able to roll mass and c of g symbol into drawings, hopefully, this is planned.
Editing properties for the tree is a nice update I will be making use of this.
Also love seeing some improvement to release management, the ability to auto propagate back to open nodes makes a lot of sense, it was a pain to having to create part numbers in multiple places. I'll set mine to all workspaces as I can't see myself releasing a different part number from a branch.
I'm always skipping back and forth from section views so activating from the context flyout will be a good time saver.
Excellent!
You're right. After yesterday I can also no longer reproduce the phenomenon. Strange but OK.
