Improvements to Onshape - January 18th, 2018
NeilCooke
edited January 2018 in New in Onshape
Just two weeks since the last update! This update comes with some highly requested improvements to drawings, materials and custom features.
FORESHORTENED RADIUS
Radial dimensions on large concave arcs can now be foreshortened to make your Drawings easier to read.
https://onshape.wistia.com/medias/uce6nyx4vo?embedType=async&videoFoam=true&videoWidth=640
ROTATE TEXT IN DRAWINGS
A new rotation drag handle has been added to notes without leaders.
VIEW HIGHLIGHTING IN DRAWINGS
It is now much easier to discover which drawing view a section, detail or auxiliary view came from. The section line, detail circle or auxiliary projection line are now highlighted when you hover your mouse over the view and vice versa.
COMPANY-WIDE MATERIAL LIBRARIES
A Company account administrator can now add company-owned material libraries to all user accounts. To enable this, go to "My account" under your profile icon in the top right corner, then "Company", then "Preferences".
DRAG & DROP DOCUMENTS INTO FOLDERS
In the "My Onshape" filter on the Documents Page, you can now drag and drop documents and folders into other folders making it faster and easier to organize your Documents.
IMPORTING SOLID EDGE FILES
You can now import Solid Edge part files (.par) and assembly files (.asm) from version 10 through ST10. To import an assembly, create a ZIP archive file containing all the parts and assemblies, then rename the ZIP file to be the same as the top-level assembly file (for example, if the top-level assembly is called water_pump.asm then your ZIP file should be called water_pump.zip). Then import the ZIP file and Onshape will create the correct assembly structure.
EDIT PART PROPERTIES WITH FEATURESCRIPT
You can now edit part properties using FeatureScript. For example, if your custom feature creates a new part, like a spur gear, you can set its part name to be equal to the module and number of teeth.
The new setProperty function can be used to set any part properties like Name, Part number or Description as well as material and appearance.
In this simple example, a custom feature added at the end of the Feature list can be used to set the name of a part. Because custom features can be configured, you can add each "segment" of the custom Part Number feature to a configuration table and build a new part number based on the configuration selected or variable value entered.
Remember: The updates listed here are now live for all users when creating new Documents and over the next few days these features will also be available in Documents created before the date of this update.
«1
  • owen_sparks
    Sneaky Onshape people
    HWM-Water Ltd
  • patrick_anthony
    patrick_anthony Member Posts: 13 ✭✭
    Great additions :)
  • john_mcclary
    Cool stuff
    I was thinking just yesterday how I wanted a rotating text option for some flow arrows. Beat me to it this time onShape :)
    Defiantly will take advantage of featurescript properties
  • brucebartlett
    Nice One!!!  I am looking forward to getting an FS try set part name, Part No., Description, Materials, etc. Lots of potential to improve workflows here taking away some of the retyping and cutting and paste at the end of a project which drives me crazy.
  • RyanAvery
    RyanAvery Member Posts: 93 EDU
    Nice update guys. Keeping it agile!
  • MBartlett21
    In the example for the part properties with FS,
    Flange 3, Slot and Extrude 1 fail to regenerate when the config variables are: length: 100mm and Configuration: Left
    IR for AS/NZS 1100
  • 3dcad
    Purely awesome :star::star::star::star::star:
    I'm still adjusting my workflows with the last update and yet you have another package coming
    Helpful updates for everyone, drag&drop streamlines document handling and drawing improvements ease up the general frustration of making drawings.
    But company wide materials and using FS to edit part properties will be huge for certain user groups!
    //rami
    @mbartlett21 thanks, fixed it. I just threw that example together without testing thoroughly. Props to @ilya_baran for the custom feature!
  • florian
    florian Member, OS Professional Posts: 110 ✭✭✭
    Nice! Finally auto renaming parts with variables :) A few days ago I was looking for the improvement request and could not find it…
  • Foreshortened radius dimensions are awesome, this has been bugging me for a while. The view highlighting and drag and drop are going to be very useful. good work OS.
  • Ben_Misegades
    Ben_Misegades Member Posts: 133 ✭✭✭
    Agreed! Just a few days ago I ran into issues with the radius dimensions, it's like OS staff is reading my mind!
  • bryan_lagrange
    bryan_lagrange Member, User Group Leader Posts: 1,053 ✭✭✭✭✭
    Solid Edge import!!!!!! My prayers to the Onshape gods have been answered!
    Next step, ability to upload a Solid Edge sheet metal model and flatten it in Onshape.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • famadorian
    famadorian Member Posts: 390 ✭✭✭
    oh, no; I thought we were done with folders. Folders is a paradigm of the last century. The structure for organization that is future proof is tags.
  • owen_sparks
    Yes indeed, and in onshape speak they're known as labels and work very well indeed, but for those that still wish to use folders they're available too.  :)
    Owen S
    HWM-Water Ltd
  • bryan_lagrange
    Just noticed for Solid Edge..... Onshape can open .par and .asm.......When will we see the ability to open .psm? This is the file extension for Sheet metal parts in Solid Edge.
    Bryan Lagrange
  • hans_haenlein
    hans_haenlein Member Posts: 9 PRO
    I've just been told that:
    Onshape has been updated to address your ticket:
    "Show sketches in existing drawing views"
    This update (1.74.20341.43fc8fee8221) has been pushed to cad.onshape.com and is live for all users of Onshape. This version is displayed at the bottom of the Documents page or by clicking the ? menu and selecting About.
    I've got the update ok, but I can't find where this function has been placed. I've regenerated the drawing, and when I right-click over the view I'm not seeing anything like Show Sketch, not finding it any where else either.  Any clues?
    @hans_haenlein looks like that has been sent in error.
  • lougallo
    lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,021 image
    @hans_haenlein I am not sure how that was closed.. Sorry about that. It is in the works.  `Lou
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
  • hans_haenlein
    OK, thanks. I was excited there for a moment.
  • emagdalenaC2i
    Un saludo,
  • owen_sparks
    If we follow the current trend of updates it has been 3 weeks and then 2 weeks, so next must be 1 week and zero weeks so that's 2 new releases tomorrow then, happy days.
    OwS.
    HWM-Water Ltd
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,279 image
  • john_mcclary
    @ilya_baran Nailed It
  • owen_sparks
    @ilya_baran
    Well played Sir.  I was going with the poncy Latin "reductio ad absurdum" but like yours better :):)
    Cheers,
    Owen S.
    HWM-Water Ltd
  • sebastian_glanzner
    sebastian_glanzner Member, Developers Posts: 500 PRO
    @owen_sparks If you look closely to the dates, you can see that the update from 2nd January was 1 week too late and the update from 18th of January was just on time :D
  • john_mceleney
    john_mceleney Onshape Employees Posts: 57 image
    @sebastian_glanzner Santa needs a break every once in a while too : -)
  • john_mcclary
    Santa gets 364 days of rest... Get back to work!
    edited January 2018
    That's all right, the whole Onshape Team deserverd it!
    I didn't knew that Santa is also working for Onshape  :D
    Now I understand how all these "Improvement Requests" and "Wishlists" work:
    Only the "well-behaving" customers get their wishes granted in the next update ;)
    PS: Can I get a color switch in Onshape?  :) Please? https://forum.onshape.com/discussion/8146/
