@michael_mcclain Thanks and looking forward to you sharing the library here to be sure! Maybe @NeilCooke can give anymore info or tease if the BEAM's is still being developed...
Lord knows there are more profiles than I'll ever use, but I was bored a few days and just went for it. I'll make a post on Monday and see where that goes
Here you can see a sample of aluminium profiles with a FeatureScript we have created
@emagdalenaC2C Thanks for sharing that video. However, without 3D Sketches (makes it much more efficient) and actually supplying all of the standard profiles (ANSI INCH especially for US) right on login makes it much more difficult to permeate to the team and others will have this same problem without an expert on site. I see this as a recognized Learning Path Center course which will be important for new users in special machine design to be certified in at companies to be sure.
SW has this "Standard Library of Profiles) and I hope Onshape follows suite, but better!
There are also a lot of standard profiles in the Beam FeatureScript
Thanks @emagdalenaC2C I'll give that a try to be sure as a start for now. Hopefully it won't be too much longer for Onshape's starting solution though.
I was happy I had a hot project in Onshape this morning. (finally a break from Solidworks) Unfortunately Onshape is too fast... Whole project only lasted half our..
sigh.. back to SW again...
@philip_thomas - Good deal, thanks for the tease, albeit 010010100011 (code). I can't wait to see what @NeilCooke & #TEAM is cooking, but it's summer and don't want it to go by too fast.
For now I will just say 'maybe'
Missing Onshape's lossless work flow. (Not needing to save)
SW just glitched out on me and wouldn't display dimensions (although I could edit them if i was clever enough to click on the invisible dim)
Unfortunately, The save button quit working also... So guess who has two thumbs and gets to re-do a weldment.... This guy
https://youtu.be/FRbAjs01FJY
Maybe it's just because your not running the latest version
didn't find mention about enabling the Save button on 2018 or even 2019 beta though..
Solidworks has only been up and running on my computer today for the creation of this weldment, and already it is unstable... It was displaying the cut profile up until I changed the color of the weldment... lol this is what it did:
https://www.youtube.com/watch?v=F-gft4QGTIE
There is a second bit of annoyance in this video too, where solidworks can't even remember where your toolbars go even though they are locked (that is a once a month issue where I have to re-sort the toolbar) Stupid Solidworks.. Onshape can remember toolbars even on computers it's never been run on
It just feels right that my 100th vote-up was lamenting old-school cad... Thanks @john_mcclary!
Rinse and repeat each "annual" release...
